Hi
I am unable to attach wall to roof by "connect from top" option. even though imply relationship lock is on, its not working. please help me .i am using v8xm. thanks
jay
This part of the prodect does not work well and needs to be improved.
Make sure simple things like cuts in the wall are not impeeding your desired effect.
for many cuts to roof I've hadto think of this like l am buidling it. Many walls I extrude a wall to the exact height as CMU does not cut to a sloped roof for exable but stops at a perceived height.
If I have sloped tops to represent wood I might have to top each wall to a line.
BUT there are times when walls are too sloped and with the walls at angles or curves you must extedn to form above. This does not always work but many times it is because of somehting simple line a cut in the way. Make sure the wall has not cuts AND is lower in height than the ENTIRE form above.
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
is this information still relevant after 12 years?
Dan,
You can use 'Adjust Top' command in order to achieve above result.
Please find online help here 'Adjust Top (bentley.com)'
HTH,
Best Regards,
Sandeep
