We are just starting to get into exporting our Bentley Architecture models in GBxml to look at them in TAS.
Having a problem with the export process.
Seems to go through all the steps fine but when it comes entering the ZIP / PIN Code it will not accept anything we key in.
Therefore we can not export.
Working in Sydney in Australia.
Does anyone know where we can get ZIP /PIN codes that the export process will accept? as it does not accept out standard zip codes
Hi Andrea, it's not clear whether the ABD model has a floor, ceiling and four walls that are all touching? If so, then what is the exact error mesage you are getting when attempting to generate the Energy Analysis model?
