Building View - .dwg
I need to be able to send consultants .dwg files that respect the building view options. (doors should create openings in walls, etc.)  Currently we are setting up files in the following manner:
Reference my Building View into the default model of my sheet file at true scale. Switch to the sheet model and reference the default model and scale it down to the required drawing scale to fit the sheet. When i perform a save as .dwg, the drawings reverts to the master model top view losing all Building View settings.
Is there a process or setting i am missing?
Parents Reply
  • DGammie:
    So long as the BV is referenced into a drawing. If you export straight from the model, with a BV on, you will just export the whole model.
    Correct...   When applying a BV to a 3D model, you'd still be saving a 3D model to DWG.  So the output is and should be a "normal" 3D model since there is no equivalent to a DV in AutoCAD.   Only when applying that BV through a reference file does the Merge Visible Edges option (a Reference setting) take effect.
    That doesn't mean the process couldn't be more automated or "user friendly" though...  that's an aspect we're taking seriously!
