Why I can not active PC Studio in Bentley Architecture?
When I select the Element Information tool and identify a PAZ file in the open model and click the Edit button in the Parametric tab, I found I could not open the PC Studio application. I have tried several times but all failed. Does anyone know how to resolve this issue?
  • After making changes to PC cell in PC studio how is this information saved back to cell.
    I changed some variable settings and selected save, save and return and nothing
    happened to cell in drawing.
    What am I doing incorrectly.
    Thanks, Tom
  • that should work in hte current release as i just did this to check.  If it is somehting wrong with a homemade cell that could be it.
    I jsut had a cell that would not change until I removed one variable that had a conflict then things worked.
    Ustn since 1988
    SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64b
    Eric D. Milberger
    Architect + Master Planner + BIM
    Senior  Master Planner NASA - Marshall Space Flight Center
    The Milberger Architectural Group, llc
Reply
    Ustn since 1988
    Eric D. Milberger
