Just starting to climb the mountain of dynamic views / building views.
One problem I'm struggling with right now, is that I am losing the fill (hatch) in walls when activating back view. Any hints why?
Andreas, could you post a before and after screen capture? If possible, show the end results (of course) and also where the cut plane and back distance fall.
Have a look at saved view plan 1, for example.
I filed a SR on that one, btw.
<Andreas Zieritz> wrote in message news:119587@communities.bentley.com... Have a look at saved view plan 1, for example. I filed a SR on that one, btw. http://communities.bentley.com/Products/Building/Building_Analysis___Design/f/5917/t/51643.aspx#119587
regards / Thomas Voghera
DGammie:Try changing the back view display style to wireframe
Good catch! If you take a typical plan BV and rotate it to an isometric angle, you'll see that the Cut, Forward and Back graphics fall at their actual elevations - middle, bottom and top respectively. So, from a plan perspective the Back graphics are actually "on top" of the section graphics, and if set to anything other than wireframe they will obscure them.
