Bentley Architecture v8i or XM. Is there any way to convert BA elements to Microstation plain solids/smart solids? Is it also possible to convert such complex elements as windows or doors to shared cells?
If this is not new for the forum (I tried to search but no luck), please, pick me to the thread. Thank you in advance!
Key in: TFRemove all (This will remove all the TriForma "intelligence" from the file)
Your components will then become cells.
Another keyin that works well with many elements is CONVERT BREP, which results in a SmartSolid. Between TFREMOVE and CONVERT BREP you should be pretty well covered.
