Generic Forms - Walls, Wall Assemblies and DG Walls
FIRST:  the terminology of this product is lacking as you can build a wall with a Generic WALL (it is a wall not a form as it has top- bottom and 4 side), An Assembly (Which is a group of Generic Walls) and DG Wall (Which adds Date we don't even use yet)(CONFUSING as this is called the wall tool not the DG Wall tool, when the old wall tool is really the Generic form whcih is actually a Generic wall as a form has 6 sides and ignores top and bottom)  Well enough for the confusion.
I need a better way to use these tools.  My first question to ALL is do you use the DGWall tool???  Do you take advantage of taggin the wall in a section with DG Data?
I WANT 2 (TWO ) tools.  One for the Power USe and one for single instance and sometime users.
The POWER TOOLS
  1. A way to quickly import old parts and assemblies into DGWalls.  Allow import into specific DGWall Catecories.
  2. A Spreadsheet like Approach (similar to parts) so that I can perform mass editing on those DGWalls
  3. Maintain spreadsheets for Parts and Assemblies but include the Datagroup info so I can make mass changes and adjustments.  (ie, apply spec number (mark) to all my CMU block at once)
The SINGULAR instance Approach.:
  1. When I crate a part I want it to ask if it is for a Wal, Roof, Floor, Generic, etc.
  2. Then if Generic - It shows a singular Dialog (NO XML SPREDSHEET) for all things I change to that wall.  Thsi does include some gerneric DG information
  3. Then if Once of the other groups:  ONE dialog - (NO TABS) and all the DG idata,  The top would say what type fo assembly it is (WALL or Floor, etc.)
Right NOW there is no reason to use or upgrade to DGWalls.  I question if anyone is using them.
You can build an entire project with Generic Walls and it looks the SAME.
The UNIFORMAT walls provided to not have any descriptive infomraiton that can be pulled into a keynote for sections
The Uniformat Names if used in a keynote would be unrecognizable to anyone in the construction profession
The Uniformat numbers would not match anyone's specifications in the industy.
NOTHIGN from the DGWalls Data is utilized yet (Though the potential exists)  You canot toggle for 4-hour walls YET.  You cannot have it generate graphics for Fire WALLS YET - You cannot view drawings for Existing - Demo - New - YET.
AND it takes so much extra time to duplicate your work by create a Part - then Assembly - Then DGWall  - before you can even place that wall that won't even use the date YET.
  • IS anyone using the DGWalls beyond just placing a wall.  How does it make work quicke, easier, more reliable.  Is it  being used to label sections, plans, etc?????
    Ustn since 1988
    SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64b
    Eric D. Milberger
    Architect + Master Planner + BIM
    Senior  Master Planner NASA - Marshall Space Flight Center
    The Milberger Architectural Group, llc
  • There are people using DG Walls currently, and I will offer these benefits to using them now (and knowing there are more coming).
    • DG Annotation
      • Create a wall annotation tag and a rule to automatically place Wall tags on plans
    • Automatic Family/Part Assignment
      • This prevents users from not changing the Family/Part and placing walls with the wrong Part.
    • Changing from a single leaf wall to a compound wall (or vice versa)
    • Easy create a DG Catalog of "standard" walls that already have all of the data entered that is typically shown in a partition schedule.
    • DG data is easy to harvest from I-Models using Item Sets for analysis of the model, isolation of elements, model checking, etc.
    I am not sure if I completely understand your requests for functionality, but I would recommend a workflow where you start out placing a "generic" wall through the DG based Wall Tool.  Then as you develop the project you can 'modify' that wall and exchange it for a more specific wall or compound wall with the data attached that matches the project (or corporate) partition schedule.
     I have made the conversion of walls from Family/Part based to DG walls for 2 different companies now, and can attest to it is not nearly as much work as it may seem before you start.  If you are comfortable working with the .xml's directly it is even easier.
     -Travis
  • Emilberger,
    As Travis mentioned, our office has set up and uses only datagroup walls.
    The datagroup information for each wall is completely filled out. Rating of wall,
    stud size, layers of gyp, sound batts, part definitions, and most important a unique tag.
    The tag schedules are standardized for the office and never change.
    Once a wall is tagged it remains linked to wall. As project develops
    and walls change for various reasons, the tag is automatically updated.
    Haven't gone to the extent of automatically tagging walls throught BV rules,
    we still haven't moved to Building Views yet. Still using extractions.
    HTH,
    Tom
  • ONE:
    My issue is I have over 2000 parts and need to go into Each and every one and no create a NEW DG wall.
    I do see the beneift from a Tag - but since my part name is the "SpecNo-Desc"  it is just a pain and I will lose so much time just creating walls for tags.  And I still asume the tag is for each individual part in a wall and not must the wall assembly.
    I've never seen a wall or partition schedule.  Talked with several friends this evening with projects from 25 mil down and that is new to all of us.  I woul dliek to see an example of someone's schedule as this may be something I can use.
    Since our firm has no draftsmen and all are architects or engineers.  The time to recreate DG Walls from Parts could be made simlier with a utility to bring all parts into DGwalls.
    TWO:
    In most packages I use I can manipulate an elment from within one singluar dialog.  With parts I must open 5 dialogs to make changes to or correct one PART.  Yes there are shortcuts by opening the spreadsheet - scrolling backand forth as they still don't fit on a 27" wide screen monitor., scroll up an down copy al other part then open the five dialogs to make the changes.
    This is less user frinding than we had in architectural products 20 years ago when WYSIWIG was considered an important need.  I can even remember at least two of the Bentley brothers saying this was why Microstation was so much better than Autocad.  We have gone backwards from userfriendliness to geekness.
    Ustn since 1988
    Eric D. Milberger
  • Emilberger,
    I originally too had many parts for walls.
    However, when I transitioned to datagroup walls the number was significantly reduced.
    With datagroup walls, the part is only used for the graphical display of the wall.
    For instance, I originally had a part for 2 1/2", 3 5/8", 6", and 8" 1 hour stud walls with 1 layer
    of gyp board on each side. I also had a part for  2 1/2", 3 5/8", 6", and 8" 1 hour stud walls with 1 layer
    of gyp board on one side and 2 layers of gyp bd on the other side. In addition to these parts,
    I also had another 8 parts for the same walls except with batt insulation.
    All 16 of these walls had a 1 hour centerline embedded.
    However, now I only have a part for 1 hour gyp walls with centerlines embedded; 1 with sound batts
    and the other without sound batts. So I have 2 parts to cover all 16 instances.
    The thickness of the wall is detemined by the datagroup definition.
    For you reference, I have attached a pdf of our Type A walls. (1 Layer gyp on each side of metal stud)
    The main tag number would consist of a letter and two numbers.
    i.e. A31
    Also part of my tag consists of two subscripts.
    One of the subscripts determines if the wall is either a smoke barrier wall
    or a smoke partition wall.
    The other subscript would determine if the wall also is lead lined.
    With this approach the one Type A legend covers every instance of a single metal stud
    with a single layer gyp board on each side.
    We have a partition legend sheet that consists of type A thru N that covers all our interior paritition needs.
    All but 3 of the legends are single datagroup walls. We do have three wall legends for our plumbing chase walls.
    These utilize compound walls.
    Note that the legends are for interior paritions only.
    Our exterior walls are not tagged but described usually in wall sections.
    HTH
    Tom
