adding views and sections in sheets
HI all
I am new to this bentley products.I am using Benltley Arch v8xm edition.
i would like to know how to creat callouts and sections and how to add these views in sheets like in revit and as well as
how can create this title block sheets like in revit.
please provide any tutorial if you have any.
thanks
hari
  • You've asked a lot of questions.  First I would start by asking.  Why not V8i????  BV is a part of V8i and closer to what you see in Revit.
    Revit and Autocad Title Block Sheets are not very useful.
    Go to a set of drawing that are 10 years old.  By opening the directory do you know what you have and to what scale ... NO
    When you open a sheet - all drawings are scaled relative to the 1st drawing.  Sometimes that plan is 1/8" and sometimes 1/16".  So a Section that is 1/2" placed on those two sheets are blocks drawn at two different scales.
    Fist draw all thing REAL and make your text fit the scale it will be plotted at.  SO all drawings are real and if my plan will typically be plotted at 1/8" scale the text is 12"
    Now draw your drawings   and then your title block REAL.  My title Block is 24"x36" and go to the model and attach a boundary (mine is arch D)
    Now reference your drawings onto the sheet.
    Reference scale are easy.  An 1/8" plan is always 1:96 Imperial
    and 1/2" detail is always 1:24 etc.
    (The reference salce is the inverse of the scale 1/8"=8 times 12 or 96)
    clip your plans as needed.
    then place that same plan or portion of that plan,elevation, etc on as many sheets as you want.
    AND then as compared to Autocad you only have to make a chage to the original plan not every sheet.
    Ustn since 1988
    SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64b
    Eric D. Milberger
    Architect + Master Planner + BIM
    Senior  Master Planner NASA - Marshall Space Flight Center
    The Milberger Architectural Group, llc
