I have a single door with glazing and a set of double doors with glazing. All the settings are the same for both, yet the glazing shows correctly in the single door and not in the double doors. I've checked the settings numerous times and played around with them to no avail. Is there something basic that I'm missing? Any ideas?
Can you post your two cells?
Tom
Here's the first one.
Here's the second. I've been messing around with this one, so the settings don't match the single one anymore, but if you can figure out what I'm doing wrong, that would be excellent!
Donna,It appears that the right door is missing the cut through the "Door Leaf Extrusion"The first image indicates how to tell if a solid has a cut and the second imageindicates were it is missing and tool to add a cut.Also note that the Single Door has the "glasspanel component" as a sub component under the Main Door component.But the Right Door in the double door cell appears to have been created by placing a component of a solid door andthen attaching the "glasspanel component" separately. If this is too confusing just let me know and I will try and clarify.
Thanks, Tom
Hi Tom,
I went back to an earlier version where the glass component was a subcomponent of the door and the cutout was there, but the glass still doesn't show up.Under GlassBaseHeight and GlassLimit thers an icon for Positioner_12 which indicates " Model Elements for which there is no specific icon". Is this part of the problem & how do I correct it?
Thanks!
Donna
