I have this problem with the V8i version.
Once I draw spaces in extracted drawings, I can delete the text, but not the boundary...and the layer is not locked.
I can only delete it after exploding it, but this is not convenient.
Somebody can help?
Thank you
Marianna
Marianna, if you really need to delete a space that was placed directly in an extraction model, try this: Select the space boundary space; Open the MicroStation Keyin window and type TFREMOVE; accept the selection; delete the space. At this point, both the space boundary and label should be removed.
Thank you very much Steve!
It works.
You're welcome.
