unwanted automatic elliptic annotation cell for Doors in dynamic views V8i
Hi everybody,
after placing a door (or a window) in the 3D model, I get an elliptic annotation cell automatic generated for the door in the dynamic plan view.
How can I changed this setting? I saw that another annotation with width and height also exists and would be better, but I can not set it as active (or actually it seem that I can, but it still uses the elliptic one).
I followed the post under http://communities.bentley.com/product/building/building_analysis__design/f/5917/t/40318.aspx, but it regards the older version without dynamic views. I could follow the steps and I could place the right annotation cell in the 3D model, but switching to the dynamic plan view I would still have the elliptic annotation cell (together with the right one placed on the 3D model).
The best solution would be to have the Width-Hight cell (alone) automatic on the plan view without putting it in the 3D model, but if it's not possible, at least to have it from the 3D model without the elliptic one (which is automatic generated...and not possible to delete).
I attached some screenshots...hopefully they help you to understand the problem.
Does anyone have a solution?
