A DEM drawing definition in v8i uses Forward Part Mapping. Any parts defined for forward mapping that are in a reference attachment are not re-symbolized as expected...
However, If I open the same group model and part mapping file on XM the drawing extraction is correct. If I merge the references together in v8i and run the extraction against the Master file only. the re-symbolize works as expected...Has this functionailty been deprecated in v8i?
Hmm... Not that I'm aware of. I would recommend reporting this to support for follow up. There could be something changed in V8i, I just haven't personally come across it.
Thsi was reported in the Shirt to V8i and was told WAD until implimented in VS's
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
