Working with Annotation Cells in V8i I expected the same behavior as with the XM version.Expectation that the annotation cells would update automatically when the Door ID instance data is modified.The instance data is updated correctly, however the cell fails to update, even if placed in the design file or across the reference attachment of an extraction view.
All is well if I use a Building View configuration.
Has this functionality been deprecated in V8i?
An interim patch is now available, please contact TSG or you can wait for the official patch which will be posted on SELECT Downloads within the next couple of weeks.
HTH, - Jeff
