DWG Conversion of DG Annotation in Reference File
Using USTN (SS2) 08.11.07.470 and BA (08.11.07.88)
Converting DGN Sheet compostion(s) to DWG 2010.
Sheet Composition uses a reference file of a floor plan extraction from DEM or Dynamic View (via Drawing Model)
In this case the DG Annotation Door tag is placed in the extraction file at 1/8" scale, however the Sheet is using 3/16".
No issue with the scale change, I will just use the new feature of using the annoation scale of the active design file to override the reference annoation scale (see screen shot). Everything looks good in the active design file and when printing.
However, when this sheet file is converted to DWG 2010, in this case merging all the reference files into cells.
The DG Annotation Door Tag cell from the "reference file" is not what is expected in the DWG file.
(see screen shot)
This issue is reproducable regardless of nesting level or if using Dynamic Views (nested inside Drawing Models).
As long as the annotation scale is kept consistent between the design file and any references attached, all is well with the DWG output.
However, if using multi-scale composition and leveraging the "Use Active Annotation Scale" feature of attachment settings dialog, output results may vary..
Anybody else seeing this?
