Dear All,
I am designing aRCC 7 Storey appartment building in which all the slabs are supported on shear walls only using staad pro. There are no columns and beams.
Can any one upload a input file of similar building based on Indian codes codes.
My approach is
1) Generate concretesurfaces & shear walls & assign parameters
2) Mass modeling by considering all the joint as hinge
3)applying Load Combination (DL+ .75LL) to get joint weights
4) Applying IS 1893 load
Seismic in X -Direction
sesimic in Z Direction
5)Applying joint weights
6) Applying floor laod
7) Element Loads
8) Perform Analysis
9) Start concrete Design
Units Newton MM
Design Shear Wall
End Concrete Design
Finish
Is my approach correct?????? How to extract reinforcement???????
Thanks in Advance???????
regards,
Atul
atulkumarengineer@gmail.com
