PB with extraction DEM
Hi
i have a pb when i extract. i'am going to migrate from V8 2004 + TRIFORMA to 8I + Arhitecture.
My pb is that the DEM don't calculate me some cells and i don't know why.
I attach a file with some cells and a drawing def. This cells are calculated in triforma with v8 2004 (the same file, the same def !!!).
So i try with the DV. it's work but make appears other pb. My dv are ok. No pb with the DV but i can't print them with a pen table. The color are not good.
Maybe it's impossible to print a dv with a pen tables??
So i try to save my dv in 2D (save as). all the cell works but i have some hidden line (only on hiddenline of wall that are holed or with hole) that have dissapeared!!! But they are on my dv.
i don't know how working?? If someone have an idea?
If you can tell me how you are working in 3d with BA to make your extraction.
Thanks and sorry for my poor english.
Cellules.dgn
  • Hello pjf,
    Do you know where is "tftypes.h"?
    I just want to call function "mdlTFElmdscr_getApplicationType", but after i include "mdltfelmdscr.fdf" in my program, compile my program, it's a error that can not find "tftypes.h".
    Can you help me?
  • No sorry,
    i don't know. no Knowledge in program. I have just make a config from V82004 to V8I and make some basics macro. i am just a little Draftsman who have pb to work in 3D because somethings (i expose that in a message before) that work in triforma are not working with the V8I.
    So i find a way to make section extraction in 3D otherwise i can return to 2D (i don't hope...lol). Bentley is searching answer to my question so i wait.
    I give you the result of this research but if you can tell me how you work in 3D and what's your way to make extraction, it's would be nice (me SS2+Architecture).
Reply
  • No sorry,
