We started with levels, added parts/families and have come to datagroups now. I think we might have a small bug when trying to change properties.
Can someone confirm this?
Andreas, which type of object are you modifying?
The problem seems to occur just when changing datagroup instance data for slabs, it works for walls.
I'm a little confused.... you're adding instance data to a slab form after placement, and then changing it? Because it seems as though part assignments are not included when adding instance data tto an object after the fact, but only during placement.
Correct, the workflow is this.
- place slab
- add instance data
- modify instance data
When placing walls, the instance data is included automatically, for slabs it isn't.
Gotcha. FWIW, slabs will be placed as DG obects in AECOsim Building Designer.
I've got the same problem with columns.
When changing columns from steel to concrete, the part is changed, but the level is not.
