Hi
Is there some settings or config variables that effect the default Flyover Preferences?
I would like to set it up for all my users and then if they'd like to, they can change them individually.
BTW, it would be nice if I could use any field from DataGroup system.
Best regards
Jonas
Jonas,
The flyover preferences are stored in the user preference file.
To roll them out to everyone, you could create a user preference seed file, set the MS_USERPREFSEED configuration variable to point to that seed and then delete everyone's user preference. The new user preference that is created will be based on your new user pref seed and will contain the new Flyover Preferences. Of course, if anyone has any preferences set, they will need to reset them.
You are limited to the options that are available in the dialog. We did rework the defaults for Building Designer. Check them out if you haven't yet:
In the help file there is a list of options you can use to modify the Flyover preferences.
But generally if you open up the settings dialog ( under top menu Architecture>Flyover Preferences/ ) and then click on the item you wish to edit in the Element type plane, then right click on the left window pane you will be able to select what you wish to add into this dialog.
Very cool tip that one..
regards
Damon
OK, then I know. I look forward to BD. Thanks
and if you use InfoSnap you can get almost anything you want into the pop-up. And easier to manage.
regards / Thomas Voghera
Wheres the link Thomas.. if your gonna unashamedly plug something at least put in a link.. sheesh..
:) :) :LOL
www.ustation.sedownload infosnap today! yay!
