DG annotations moves to center of object (window, door)
On the sheet model, if I place a DG annotation for a window or door (ID) and then turn off and on the "Dynamic View" floor plan reference, the DG moves to the center of the object. See before and after pictures below.  How can I make the DG annotation stay where I placed it in the first place?  This also occurs if the "Dynamic View is updated.
