Read if you want a challenge. I've spent enough time researching it and it is driving me crazy.
Does anyone know how to change the drawing name for a linked callout after it is placed? I’m experimenting with the linked callouts and in particular the Drawing Title for the floor plan view. In my BIM model (design model), I used the task Create Views > Floor Plan View command. I activated the Create Dynamic View option. After clicking in the view, I got the Create Dynamic View dialog box.
I understand that the name field here is critical. At first, I set the name to FLOOR PLAN. After clicking OK, the drawing view and sheet view are created. Here comes the challenge. The Sheet Name and Drawing Name both inherit the name "FLOOR PLAN". I figured out how to change the sheet name by editing the model properties of the sheet model > Sheet Properties > Sheet Name item (A-401). I cannot figure out how to change the drawing name from FLOOR PLAN to something like RESTROOM PLAN.
Good luck.
Travis, changing the "name" in the element properties worked for me as you stated. Thanks again for the help.
Mark Mates - BIM Manager - Mason & Hanger
Glad I could help.
-travis
Sorry - I had the same problem and tech support help with the answer I provided earlier.
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
No problem. In this community, you've helped more than not. :)
Select "Properties" when you right-click the title. You edit there
