I agree - also using feature forms with constraints and a compound cell.
But someone has to be willing to make small changes within these areas to tie them together
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
Rabi,
Are you saying that you would recomend using GC other then PCS? An if so I have one question on that. When using GC can you create doors, windows, ect. that can be used in Bentley Architectural?
I liek the result of PCS but it is very hard to use.
I can acheive a model of somehting far quicker in MS but lose the variables such as height and width. If someone can build a stair with these smarts I could probably do more in MS 9(as I know this product) and somehow make constrained compound cells, but:
1. I must be able to use Parts of Catalog Instances
2. Id need vatiables that I could edit like I do on doors and windows.
3. Be able to edit compound cells and have them stay compund cells.
Snc12: Rabi, Are you saying that you would recomend using GC other then PCS? An if so I have one question on that. When using GC can you create doors, windows, ect. that can be used in Bentley Architectural?
I believe that the poster was indicating that it would be nice to generate parametric cells from GC, but GC does not currently support this.
Tim Grimm: it would be nice to generate parametric cells from GC, but GC does not currently support this.
