is there a way how to force the lower and upper edge of the wall to be connected to the specific floors? what I'm trying to get is when I place a wall on a floor and then change the height of this floor, the wall updates automatically ..
thanks
p.
I'm fairly certain there is currently not a way to tie those together. Your looking at using the modify wall tool, and you can select multiple walls with a selection set and modify them all to the same height.
If I find out a better way to achieve what your asking, or find out if it might be in the works, I'll let you know.
Paul,
thanks for reply, I thought it would be like this ;-)
I know, I can modify selection, but I was thinking not only about walls, but in general about building modeling concept. If we have a tool called "floors", then it should act like real floor, not just like named ACS with no relationship to the geometry placed on this "floor" ... btw, there is a similar thread here ...
/pt
