Hello
For some reason, whenever I use the Place door command in BA, the value box where you can edit the various components of the door does not appear? Is there a switch somewhere to activate this?
Mo
Ideally in Place Door dialogue , you should get property value field active. It does not remain active for Modify door dialogue where you need to select 'Active column for that property to enable field.
Can you please post image of the problem dialogue ?
Sandeep
Hi!
Screen shot of dialog box attached as pdf.
It look as though the Value column has gone on holiday... Try exiting BA, renaming your local \pefs folder, then restarting BA. Does that help?
Surprised to see this image as you cannot drag any column and change it's position in door placement UI. As "Value" column is in between "Property" and "Query" columns and cannot be interchanged , it must stay there.....As Steve suggest, try renaming prefs and open BA session again, that might help.
Still I'm trying to simulate the issue at my end....
Hi Steve
Thanks for responding.
I created a new user pref using the New option at File Open stage. With the new user pref, the value box returns :-)
The previous upf that appeared to be problematic was called triforma - I deleted that, and created a new one called triforma using the new option, (just to see if it works!!) and believe it or not, the value box disappeared again. So I guess, the problem was using a upf called triforma?? not sure i understand why, but the workaround works, so I'll move on from there. Thanks for your help.
kind regards
