Hello
Is it safe to assume that the metric dataset that was made available for the Beta version of AECOSIM can be used with the current version of AECOSIM. If not, is there any indication of a timeline when this will be available?
Yes, very good news indeed! You might almost think the US was converting to metric or something. ;-)
No way! e.g. you couldn't run NASA on metric
I suppose that's true... though now you could model a "generic" launch pad in metric. ;-)
Yes, we've got a Swedish dataset for ss4. Installed fine, and seems to work fine.
Some has worked more than they expected to get this out. Thanks, it is needed when working with ABD.
regards / Thomas Voghera
So we now have a SS5 released, and still no metric dataset.
They will never learn...
