Is there a way to change the Identification of multiple ducts all at the same time?
By "Identification", do you mean DataGroup Instance Data? If so, select the multiple ducts, and then use the Modify Instance Data tool instead of Modify Component (mechanical). This tool is on the DataGroup System toolbar or in the Project Management > DataGroup - Building Components > Modify Existing Data... menu.
Mark Mates - BIM Manager - Mason & Hanger
Hi Vicente,
Please include the version you are using in your post. Thanks
Mark's reply is good for DataGroup information.
You may be asking about the Family:Part assingment, for example: Supply-New?
Hi Paul,
You are correct i was refering to Family:Part assignment. Actually the Architecture task has no problem but not in any of the HVAC or Plumbing tasks of the AECOSim Building Designer v.08.11.09.225.
If all you want to do is change the assigned part, you can use the Apply Part tool - that will work on selection sets.
The Apply Part tool is incorporated into the Change Attributes set of tools in the Main Tool box found at the top of the Task Interface. Select the tool and check the Tool Settings, I always recommend turning on Apply Part's Default Symbology and Apply Part's Default Level.
You can also use the keyboard navigation feature to access the tool. With the focus Home (pressing <Esc> will move the focus to 'home') press<5> to open the Change Attributes tools and <9> to run the Apply Parts tool.
