Parametric Cell Studio - Perforators
Is it possible to create a PAZ / Compound cell that will perforate a (compound) wall form vertically?
or
Is it possible to create a 3D "subtractive" perforator for complex geometry?
Currently if I draw a shape in plan to use as a perforator it does not seem to cut. Is it that only perforators drawn in elevation will work?
  • It looks to me like, the cell perforator's SenseDistance property is hard coded to the placement tools SenseDistance field meaning the placement SenseDistance value overrides the cells built in cut distance.
    This seems to be a unique situation, as all the other placement properties seem to be one off placement options, or are driven by the datagroup definition files.
    This is unfortunate in that there is (should be) a difference between SenseDistance and CutDistance
    Can the SenseDistance attribute (controlling cut depth) in the cell be disassociated from the placement SenseDistance (controlling search depth)?
    Is there an alternative cell property (variable name), or
    Is there a configuration variable that moves the hardcoded SenseDistance to a datagorup definition, or
    Is there a way to implement a =SenseDistance vs =\SenseDistance or =SenceDistance_01, =SenseDistance_02 syntax?
  • I think it is either one or the other
    and set with the Blind Attribute in the pc cell.
    This is how to do it for a Paz Cell
    Attributes Used for Openings (Perforators)
    To create an element in your Parametric Cell which will cut an opening when placed in Bentley Architecture:
    Create a closed Path2d element which will act as the cut path in the cell.
    Rename this path2d element so that the name begins with RoughOpening. For example, RoughOpening_1
    Add the three Attributes Blind, Directional, and SenseDistance.
    Blind
    Type:   Boolean.
    Possible Values:   True or False (selected from the drop-down list box when Boolean is selected for Type)
    The Blind attribute controls the the depth of the cut with respect to the Sense Distance. If the Value assigned to Blind is False, the RoughOpening Perforator will cut all the way through any forms found within the Sense Distance. If the Value of Blind is True, then the RoughOpening Perforator will only cut to the depth of Sense Distance. This option can be used to cut pockets into forms for recessed cabinets, sliding doors etc.
    Directional
    Type:  Integer
    Possible Values:   2,  1, or  -1
    The Directional attribute controls the direction of the cut from the RoughOpening path when the cell in placed in Bentley Architecture. If the Value of Directional is 2, then the cut will be 2 way, that is, it will cut in both directions perpedicular to the plane of the path. If the Value of Directional is 1, then the direction of the cut will be outward from the path. If the Value of Directional is -1, then the direction of the cut will be inwards from the path. For use in Doors and windows, the logical value of Directional will be either 2 or -1.
    SenseDistance
    Type:  Length
    Possible Values:   any length value.
    Sense Distance is the distance which Triforma will search from a perforator for elements to cut. The SenseDistance attribute contains the default value you wish to apply to the Triforma Sense Distance search. This value can be modified in the tool dialog at placement time or in the Perforators tab of the Triforma Element Info dialog when a Parametric Cell os selected.
  • Good answer Tom (?)
    My only other frustration with this was the inability to define the "Length" value of sense distance using a variable that could be modified during placement. I haven't tried it in a long while but I assume that hasn't changed.
  • Thanks Tom, I was aware of that info. My problem is when cutting "pockets" of different depths in the same paz cell. All depths get overridden by the single value stated in the datagroup catalog....
    As Dennis days being able to set this (these) depths via a variable is not possible.
  • How important is the datagroup information to you? If it isn't important you could try importing the cell directly (keyin TFPACELL IMPORT) and move it into place to see if it works the way you expect. It will import at the origin.
    This is also good way to test cells before putting them into the DG system.
