IFC Export options settings (AECOsim BD)
Can someone explain what the options below are for in the IFC export dialog box.  The help file isnt detailed enough.
Comment TAB
Project. - This seeems to want to point to a file, but what file and where.  What purpose is it?
Building - As above
Site - As above
Or is this just simple text that relates to the file your exporting?
  • Ian: to my knowledge, the items you see here are filling out Ifc Class types or IFC Entities that help document the IFC file.  For example, all of the Modifying Person items (with the exception of 'Organization') will fill out the IfcPerson entity in the schema.  Organization goes to IfcOrganization, etc.
    While you are right, it does serve to document the file itself, it looks like it's doing it in a way to present a simple way via the dialog box and populating those entities for you vs. you have to pick and choose through the process and find the entity.
    Shawn
    This document may help. Originally created for 08.11.07 but concepts may still work AECOsim.
    It outlines how Building stories are created through references.
    I find the document very helpful in this respect.
    The comments tab is also discussed. However, what it fails to mention
    is the Project, Building, and Site Data comes from a datagroup instance that has
    been attached to an element in a file.
    Not sure if it is still available for download. But IFC 2x3 extensions was available for download
  • I'd agree with Tom, you need to read the documentation, there are conventions you must use if you want to get a valid ifc file which includes floor zones for example.
    Its well documented in the guide Tom has highlighted.
    the IFC2x3 extension is still there but you need to search for it under Bentley Architecture not AECOSIM
  • I was about to post a question, but I assume from this answer that the  IFC2x3 extension is still valid in AECOsim?
    Marc
  • I'be not tried it but there is config that can be switched on the the delivered GB dataset so I'd guess yes.
Reply Children
