AECOsim Building Designer Dataset_ANZ released
On June 29, 2012, AECOsim Building Designer Dataset_ANZ 08.11.09.350 for Australia and New Zealand was released and is now available from SELECT downloads under Product Line: Building Analysis and Design, Category: Enhancements and Updates.
While most content is common for both countries, some differs, i.e. steel section tables and catalog items that use steel sections, and door and window sizes and their elevation opening indicators. Therefore, country-specific project templates add the appropirate content to the workspace via configuration variables.To use Australian content, select BuildingTemplate_AU or BuildingTemplate_AU_Extended, whereas for New Zealand content, select BuildingTemplate_NZ or BuildingTemplate_NZ_Extended.
Project templates with the '_Extended' suffix enable additional content, such as more plumbing fixtures and wall systems from Boral, CSR, James Hardie, and Stegbar, etc.
For further information, please see 'ANZ Dataset Contents HELP Guide.pdf' delivered with the dataset.
Best regards,
Volker
