Force Synchronize Cache
Dear AECO Building Users,
Does anyone know of a way of refreshing many, drawings referencing saved dynamic views with a cached visible edge?
On My AECO interface there is a command called: Visible Edges-Force Synchronize Cache
and  a macro which goes as follows:
# Command file for batchprocess utility
# This command file was originally copied from $(MS_DATA)cmdfiletemplate.txt.
# Command file information:
# - Lines that start with the '#' character are treated as comments and ignored.
reference visibleedges dynamic all
reference visibleedges cached all
filedesign
The Macro just updates the references, but if the cache goes red it does nothing.
Is there a Macro that Force Synchronizes the cached views?
My problem is I set up hundreds of drawing sheets using drawings containing referenced dynamic views, with a cached  visible Edge setting.
I am now spending my life going in each file to force Sync the cash view.
Please help! Is this a correct workflow?
Please save me.
