How can i remove all unused levels on my model? I tried using the compress option but it did not work.
Check your configs and make sure you have:
_USTN_CAPABILITY < -CAPABILITY_LEVELS_ALLOW_CREATE
instead of:
_USTN_CAPABILITY < -CAPABILITY_LEVELS_CREATE
What will i do after this?
If you have _USTN_CAPABILITY < -CAPABILITY_LEVELS_CREATE set then you can't delete unused levels when you compress. Changing it to _USTN_CAPABILITY < -CAPABILITY_LEVELS_ALLOW_CREATE allows you to delete levels when compressing.
I can still see the levels. It seems like those are the levels from the design library. Sample level is named A-F-Space(Spaces) i never used this level and i can not delete it.
If the level is just being read from a dgnlib, then it cannot be deleted. Could it be from a reference file?
