Anyone have any idea why TFWALLS would not load (or be allowed to load) in a custom AECOSim workspace...obviously I've missed some variable, but I don't see it.
Thoughts are appreciated.
You could try deleting the Wallsz.rsc file that is created under Workspace\BuildingDataset\Dataset_US\data folder and see if that would help.
Pradnya
Pradnya: I deleted the WALLSZ.RSC file, but it did not do anything different. TFWALLS still unloads.
Any other ideas? Please advise.
Shawn
Hi Shawn,
Could you send me the details on the customizations that you have done. That could help me to figure out the problem.
Just installed ABD +1 and I now get the same issue. As soon as I select the Place Wall tool, it unlads the TFWall mdl. if I manually load TFWalls it unloads straight away. Did you get anywhere with this.
ian
Worth noting, it works fine within the default install.
