Anyone have any idea why TFWALLS would not load (or be allowed to load) in a custom AECOSim workspace...obviously I've missed some variable, but I don't see it.
Thoughts are appreciated.
Just installed ABD 81109361.
Can draw walls.
Also in an old SWEdataset I installed.
regards / Thomas Voghera
I was using 08.11.09.376. Not able to draw walls, but was in previous build (release)
Please post the msdebug.txt which could help us identify the issue.
Pradnya
Ian.
Have you been using .225 or the refresh build .325 before this?
BuildingDesigner.cfg was substantially re-written at .325 so that you didn't have to edit it, because in .225 it always forced the US space as the entry point.
Its found here.
C:\Program Files (x86)\Bentley\AECOsimBuildingDesigner V8i\AECOsimBuildingDesigner\config\appl
My recollection is that because I knew I had worked on BuildingDesigner.cfg I swaped out my edited version when I installed .325 and the problems you are experiencing ring a bell.
Rob
I will give it a go tomorrow. Thank you
