1. Wondering if anyone is using this? Was the slowest part of the BV generation process.
2. Does ABD still regenerate all annotation from scratch every time?
3. If the door or any other annotation tag is moved by the user, can ABD just update the tag information, leaving the tag in place, or does it just replace the tag whole sale?
I have replaced many door "artefacts" many times. Not only after modifying or manipulating the door.
But most stay as put.
In ss1/ss2 that is, haven't tried ABD yet.
regards / Thomas Voghera
FYI:
communities.bentley.com/.../7920.aspx
Marc
Thanks Mark. I think I recognize that screen grab... Anyway, while your recommendation for 'optimum' configuration settings might be best performance in all scenarios, I would tend to encourage people to have BB_AUTOANNOTATION_ONCREATE = 1 rather than 0. This just means that at the time the DV is created it will search for qualifying rule-based annotation elements and generate the label at that time. It will not do anything to performance after that. The biggest difference will be the setting for BB_AUTOANNOTATION.
-travis
