I'm not sure that's possible with the current implementation... The overrides set in the Drawing Model are intended to be specific to that instance only, so the Saved View controls how the elements display everywhere else. Although, I did notice that you've set the orientation in the Drawing Model to "Top" and not the Saved View?
Mhm, after re-reading my initial post I'm kind of confused myself what I ment that day.
2nd try:
Setup is still the same as initial: Design-model >[Saved View, Volume only, Dynamic Visible Edges]>Drawing-model>[Standard Top or Coincident]>Sheet-model.
When I change a level on/off in the Drawing Model (after I created the sheet model) this doesn't get synced to the sheet model. This is logical because Microstation doesn't know which View it has to sync. So how can I make this happen, does this have to do with:
Perhaps this can help
communities.bentley.com/.../241231.aspx
regards / Thomas Voghera
