I have noticed these commands on the right click menu - they look useful but also a little scary to manage on larger projects.
Could people tell me how they use and manage these function and what the consensus is on them - a good thing or a bad thing?
We have concluded that for making quick and dirty save as sketch option studies there is no obvious drawback, but when you you start to look at using it on final drawings of larger buildings that might have things hidden and then re-hidden it starts to become difficult to manage consistantly.
In our office we have debated the question and comeback with wide ranging opinions from not using it at all to thoughts about careful use of it. The nub of the debate has ranged around the nature of the model and whether it is ever truly a finished entity, and as such whether downstream drawings can be truly finished.
Marc, see my response from the 1st below - you can turn on the display of these hidden elements from the reference dialog.
Beg pardon, you did point that out. Ignore my last two sentences, the first one still stands though!
Marc
No problem! I do see your point in that example, where turning off both elements probably is the best/only way to make use of the Hide function,
This is something that should be addressed in the modeling and not in "tricks" like hiding something. If this was done with forms there would not be the issue. Walls and Forms, roofs, etc, need another leap, in that (just like in this example of same materials) are just basically forms. And during placemnt top and bottom are relevant HOWEVER after that sides are sides. Top side should be able to merge to end side.
Though I note that if both are the same material they should display as one in DV.
If they are both the same material, but different pours or constructions, would there not be a expansion joint or construction joint of some sort - and then that should be modeled.
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
Agree that Forms should be updated.
But, in this case, I think the Forms shown did not unite because the new multithreaded BV unite engine can not deal with overlapping elements....?
Or is it because they are in different families?
Walls mitres do not unite in plan when they are different heights... something similar happening here?
