Floor Plans by floor/floor set
Wondering if any progress on resolving the issue of floor rotation not being picked up by those tools...
Seems like we're still stuck on the default BASE ACS no matter what...
Right-clicking on the clip boundary or the view boundary gives the option of Align View to Clip.
What would be good is to have Align Clip to View.
Also if you modify the clip volume for any reason then the view will automatically align to the new clip... which you don't always want.
In the screenshot I've shown the auxiliary ACS (that of the view -  I had to update the initial plan view saved by the Floor Plan by Floor tool which would have defaultd to the clip orientation), while the clip aligns to the BASE ACS...
Parents Reply
  • Good to hear, thought I might have missed some obscure setting somewhere...
    That said, I ended up modifying the way I "normally" work ie usually reference the buildings into the site plan.
    What I do for the time being is reverse that process - ie rotate the building(s) so as to have ortho view, then Xref the site and rotate the Xref as needed... Which goes against what I was always taught but what to do...
