I find that if I mirror/copy a stair, the stair numbering comes out correct in the mirror copy.
If the stair is in a reference and I mirror/copy the reference, then the stair numbering gets mirrored which I obviously don't want...
Anyone come across that problem already?
Understand, and appreciate your feedback Eric, many thanks.
Marc
Hi Mark, yes it does when you mirror a stair in an active file BUT it doesn't when the stair is in a reference file that is mirrored. At least not at this end... tbc...As an aside, the reference mirror tool could do with a few more choices just as in the "live" tool - mirror about a line for instance, mirror-copy ( at present must copy first THEN mirror...) etc.
Bear in mind this is stuff I see was queried 5 or 6 years ago - although in the context of plain Microstation... But anyhow it's pretty useful to be able to mirror a reference without mirroring the text - as for instance in a duplex typical unit in a residential development.
Alternative would be to create a cell, but a different problem arise with cells in DV - the unification doesn't occur... Not to mention that for a cell that includes a stair, the origin of the cell has to be chosen to be at (0,0,0) otherwise the cell's stair will not be in the original location... At least AFAIK :-(((
I guess in the meantime we should revert to annotating stair numbers on the sheet/drawing... But from a BIM perspective (or is BIM just another paradigm?), this does seem outrageous does it not...
