AECOSim SS4 WIP crashes on IFC export
I've created a simple dgn file which crashes SS4 WIP during export to ifc.
It also crashes when clicking on spatial structure - assign building and floors, because there are no defined floor definitions (test project, very simple setup).
In my opinion it should be possible to do a quick ifc export without setting up a whole project with floor definitions.
test.dgn
Parents Reply
  • Hi Andreas,
    Yes, just tried that and IFC export worked. Recieved the following expected error messages:
    BuildingDesigner Configuration Check found 1 error.  See the Message Center for details.
    BB_FLOORMASTER_DGN points to an invalid file.
    BB_FLOORMASTER_DGN:C:\ProgramData\Bentley\AECOsimBuildingDesigner V8i Ss4\WorkSpace\projects\BuildingExamples\BuildingTemplate_US\support\dataset\dgnlib\BB_FloorMaster.dgnlib
    You should always have a valid BB_FloorMaster.dgnlib (I always recommend renamed with a project code) but it doesn't have to contain any floors or other info. I'd also suggest that when setting up a project template the example building and floors are amended to suit your own needs.
    Also recieved the following expected error messages due to the absence of the correct dataset:
    IFC: Catalog item 2235 Bjelke, stål I-profil of type Steel Beam not found
    IFC: Load setting file C:\ProgramData\Bentley\AECOsimBuildingDesigner V8i Ss4\WorkSpace\BuildingDatasets\DatasetExtensions\IFC2x3_psets\psd\Pset_BeamCommon.xml
    IFC: Catalog item 2225 Søyler, stål RHS of type Steel Column not found
    IFC: Load setting file C:\ProgramData\Bentley\AECOsimBuildingDesigner V8i Ss4\WorkSpace\BuildingDatasets\DatasetExtensions\IFC2x3_psets\psd\Pset_ColumnCommon.xml
    IFC: Catalog item 2513 Plasstøpte dekker of type Slab not found
    Marc
