iModel From Revit Questions
When a iModel is published from Revit isn't it supposed to contain intelligence?  For example, a door knows it's a door, stairs know they're stairs, etc.  The reason I am asking is that I was wondering if drawing rules could be applied to them?
John K.
  • One example that has come up between an IFC model and an iModel that I have noticed.  I cut a section of a wall that is supposed to be CMU, for instance.  If that wall is in an iModel then I just get the outline of the wall cut but if that wall is in an IFC model I get the CMU hatch pattern of the wall.  Now mind you that the IFC file was generated from ABD and the iModel was from Revit.  I'm waiting for a client to send me an IFC from Revit to see if there is a difference.  I'm also going to create an iModel from ABD and try both.
    John
  • I-models do include business data via EC schema properties, but that data is to support all disciplines - it was never intended to carry BIM intellgence such as Family & Part.   That's whay Shawn was outlining a few potential scenarios to get that data added (to what is a read-only model).
    IFC, on the other hand, was designed as a building-specific format and therefore offers things that an i-model cannot.   From a Structural perspective there's also the ISM plugin, but that won't help for Architectural components such as doors, windows, etc.
  • Hmmm...
    i-models seem like the vanilla schema.  IFC is more the building-specific schema and recognises F+P. ISM is the structural-specific schema... and therefore should also recognise F+P?
    Bentley now has quite a few translation tools:
    Platform: i-model transformer, i-model Composer, DataManager, i-model drivers for Excel, Access etc
    Building: IFC transformer, ISM Revit Link, RFA Interpreter (coming soon)
    In a BIM environment, a lot of the Ref attachments would likely to be i.dgn's or dgn's that would need to be:
    1. Cobbled together from different sources: ISM to get best fidelity for structural elements coming from Revit, IFC from another BIM app or to get the architectural stuff, i-models from other Bentley verticals etc
    2. i-model transformer has a graph-based scripting interface which will be useful to handle the inevitable customisation that will be needed to prep the info before the user can Ref the i-model (or work on the dgn).
    Should the IFC model be split into several floors, each with a nested i.dgn so that would mesh with the existing ABD model? Or split by phasing?
    I-model transformer seems to also support the use of a 'Relating Schema' to merge/associate data from an Excel table for example to the graphic/attribute elements in the i-model.
    Purpose specific filters to reduce the stuff for the task at hand...
    3. I-model transformer also seems to be able to re-map values based on scripted user requirements. It would be good to have this functionality part of the upcoming RFA Interpreter and IFC Transformation tool.
    It would be good to be able to combine the tools into one UI and 'choke point'. Interoperating with Revit would mean getting an IFC that would need to map and replace 'dumb' IFC geometry with tagged attributes with interpreted RFA's, and other DGS elements like paz, bxc, DG annotation cells etc to minimise the amount of 'zombies' we will need to deal with.... using i-model transformers rule sets and graph-based UI...?
    It should be possible to include Item Set Criteria Sets, ECQueries etc
    4. What about transaction management? Will Design History be able to version the changes to the non-graphic attributes? Sqlite? IFC GUID change tracking? ISM?
    5. What about links to GC and the upcoming Parametric Content Modeler? The RFA Interpreters seems to only work for elements that have 'counterparts' in BA that work similarly. What if you don't have one? I think you would have be able to build one using GC or PCM...
    Revit may not have an open format, but it has an API that allows the user to generate Revit elements within Revit. So, an IFC with the appropriate tags attached to the relevant elements could be converted into the native Revit element with the help of the Revit ISM plugin?
  • Looks like Nigel has an idea:  www.eatyourcad.com/article.php
    Shawn
  • Sure... but with i-model transformer you should be able to assign the F+P information to the i-model.... automated using scripts. Seems like the tools are already available.
    The RFA Interpreter seems to be doing the same thing by mapping the RFA's material assignments to F+P.
    Of course, it would be better to be able to map Object Styles to F+P...? And maybe provide some mechanism to map Phasing, View/Graphic Overrides and View Filters to their AecoSim 'counterparts'.
    Maybe even the whole ten layer 'Visibility Heirarchy' some day...?
