Datagroup explorer AECOSIM
Hi.
We works on BA with V8I select 3. not very good. so we are waiting for aecosim... in french.
I have already aecosim and begin to look at it. I have the version 225.
I have read, and i note, that when we modify a parametric cell with the edit handle, the datagroupexplorer and the item browser was not update  !! but not for the door and windows ???
Is someone knows why ? is it a bug ? is it fixed in the last update ?
I have begin to make parametric cell with PC studio, and the edit handle is a quik way to modify a cell but if we have to modify them manually to be pdate in the datagroup explorer... i think i'm not going to had edit handle to my parametric cell.
thanks
PJ
  • Yes, this is fixed in the latest release.
    See communities.bentley.com/.../86807.aspx
    (a bit down in the discussion).
  • Thanks Andreas.
    Another questions.
    I have hear that PCstudio may be replace in the future ??
    I've creating a paz cell, seems like rect penetrations for slab, but no the result as expected. i use Dynamic view to test it.
    with a top view, no pb.
    In the side and front view : when i 'm front of the cell, it's ok, i have the same result. but when i cut trought them, i have different result if i use fitted section side or fitted section front !!
    i test many case...but i have no idea of what is wrong.
    With fitted section side        With fitted section front
    In a fitted section side all is ok. it's what i want even if i don't understand why i dont see the cross !!! i have dont do anythonk in that sense.
    but i dont want to have it when i cut throught. i try the cell in all position (rotate 90,180,270) and it's ok.
    in the fitted section front, the same cell that works with a side section dont work with a front section (in all position) when i cut throught it. i have nothing.
    my DV have the same parameters. when i rotated (90°) the fitted section side (to become a fitted front side... it does'nt work anymore.
    if anyone have an idea...
    thanks.
Reply
  • Thanks Andreas.
    Another questions.
    thanks.
