Has anyone experienced problems with Callouts and dynamic views when working outside "solid working area" or when the "global Origin" is moved in the Composition model?
For example microstation tells me "maximum dependency callback iterations exceeded" when trying to "show callouts" on a sheetmodel.
Johan and MIchael, I had an issue opening some sheet files in Aecosim SS4. When I tried, file would take forever display and eventually I would receive a message "maximum dependency callback exceeded" This issue I traced to "Annotation Overlay References" created when a dynamic view is activated in composition model and reference overlay is created. They are also created when navigating to composition model through "dynamic view markers" from sheet or drawing files. If your issue is related to mine, I corrected it by removing all sheet and drawing file overlay references in composition file. After doing this my sheets would open normally until another overlay got created. Note: I filed a service ticket for this issue which based on my testing has been corrected in AecoSim SS6 update 1 - 08.11.09.863 and 08.11.09.865. HTH's Tom
