Two Issues: See the attached. ther Brown Rectagles and an "X".
ONE:
The section is a wt of 3. If I toggle on the Centerline the Section takes the Part symbology of the centerline at 0.
TWO:
The Width to wall and Scale do not work. This has worked before but still does not here.
This is what I have when centerline is on :
This is what I get when Centerline is off (correct wt on Section ) and what I drew in 2d is what I need. (On Right)
I have noticed that one insul might scale and the other might not. Is it jsut a setting in the linestyle? I have scal checked on. The Original "C" is 1SU x 1SU and the length is good in this section just not the width.
Bumping this back for help.
Right now when I create the centerline "ON I lost the whole section to the seight of the centerline.
And
The Centerline Width does not change.
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
I did find that the Custom Line I created that combined a line and points. Well the line of JUST dashes follows the width command where previously the points did also. Again, is it maybe a setting on the points?
First picture has width off and 2nd is width on.
OK Closer but I think I hit the limit.
1.
On an Shape that your centerline must go two differnt directions - one must be a slab for Hoizontal centerline and one must fe a wall for vertical.
2.
HERE I WISH WE COULD CHANGE THE ORIENTATION OF THE CENTERLINE OR MAKE THE PARTS SMARTER WITH A ANGLE FOR THE CENTERLINE.
3.
I STILL NEED A WAY TO CONTROL THE END AND BEGINNING OF A LINE.
3.a
MAY CHANGE THE "BLUE" REBAR TO A SINGULAR LINE - OR USE W.W.M. WHICH WOULD BE A DASHED LINE. BUT I NEED TO START AND STOP THE ENDS 4" FROM EDGE.
4.
The blocking has a centerline. Works great on all 2x (1 1/2") blocking.
5.
Since centerline goes top to botton I had to rotate the peices.
THIS IS WHEN TOP AND BOTTOM AND MODIFYING LENTH, WIDTH, HEGHT SHOULD DISAPPEAR AND JUST BE AN "EXTEND SIDE" PICK A SIDE ANY SIDE. hANDLES KINDA DO THIS.
6.
Then the CANT will not show a Centerline. It should and I don't know why. I have stretch and partial on and also tried every combination and it never made a difference. Are we tied to only retiliniear shapes?
THIS BEGS A QUESTION. WHY DO WE NEED CONCRETE SLABS IN 10 DIFFERENT HEIGHTS FOR PARTS.
WHY NOT ONE PART
ONE DEFINITION AND CONE COST
COSTS THAT LOOK AT THE WIDTH AND APPLY A RULE FOR ESIMATED COST OR A DIFFERNT VALUE BY THICKNESS.
THEN A PART DEFINITION THAT ALLOWS RULES. IF 4" REBAR HERE, IF 6" HERE, ETC.
THEN WE HAVE ONE PART THAT IS SMART
AND WHEN WE PLACE A WALL IT KNOWS IT'S A WALL BUT THEN THOUGH MANIPULATION IT SHOULD LOSE THAT THOUGHT. SO IF I CHOSE TO lean TWO WALLS 45 DEGREES TOWARD EACH OTHER I CAN JOIN TWO SIDES WHERE I CURRENTLY CANNOT JOIN TWO TOPS.
