Hi Folks
Need help with Frame Builder?
How I get an opening in a sandwich wall (25cm concrete, 18cm insulation, 3cm air, 1 cm composite wall), if I create the window over Frame Builder ?
What is wrong in the frame builder definition (see PDF)?
Thanks Konrad
Try PCS or compound Cells - Compound Cells are very easy
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
