Hi Folks,
how I can avoid, that in 3D model is a visible line from different floors (blue circle)!
By the way:
How you would create an fassade raster (sandwitch elements> renobond) on this 3D model
Konrad
Hmmm... There is no gap at those specific locations, and the two components use the same family & part with unification enabled?
Hi Steve,
yes they are from same family (some floor is Ok, the other vare not) cracy!
I used the function "conect forms as L (Bisector)
Thanks in advance f y support
Interesting...
I would try stretching all of those particular intersections back, and then reconnect them. Just in case there's a joint just slightly out of place that is affecting unification.
Isn't there a tolerance on the unification?
regards / Thomas Voghera
Yes, there is. But I would usually recommend rsolving any potential modeling issues first.
