I'm going through the learning path for Parametric Cell Studio Fundamentals and every time I go to close a 2D shape (even basic shapes) it crashes.
Is this an issue with my pc or is this a fault being caused by something else?
Josh,
To eliminate one possibility,
Can you attach the file and I will test it on my computer?
It maybe a file issue.
Tom
(Steve)
I've changed the Multi-display/mixed-GPU Acceleration option to Compatibility Performance Mode. It now lets me draw and close one shape, when I try to draw and close a second shape it crashes.
(Tom)
Attached is the file that I have created.
Placing shapes in attached file seems to work fine on my computer.
So the file seems fine.
Windows 7
AecoSim 08.11.09.622
Nvidia Quadro 4000 - Driver 320.86
Ok, I'm running Windows 8, could that be part of the problem?
PC Studio has started crashing on my colleagues PC as well. :/
I believe PC Studio was tested on Win8, but I'm following up with our QA team to see if they're aware of any OS-specific isssue.
FWIW, your file works perfectly normal here as well on Win7. Since Tom, yourself and I all have Nvidia cards, it's possible that there is some type of OS/hardware/driver compatibility issue happening. But it can be difficult to troubleshoot these type of issues. Can you confirm whether your colleagues have the same graphics card and drivers?
