DV's not snappable when mirrored
Hopefully a quick question for someone.
I am currently trialing AecoSIM (select series 3) and DV's for compatibility with our existing projects/company dataset and workflows.
I have come across quite a strange feature in DV's, in that when I flip DV reference, it becomes non selectable/snappable. The only elements I can get to snap are elements in the back clip view when I switch this on.
The project is a large housing development with multiple housetypes and handed versions of each.
Workflow> Seperate models created for each house type. DV's made from house Master models and referenced individual drawing files, annotation etc added here. Drawing files are then referenced into master site plan. Handed versions' references are mirrored. AS soon as mirrored, I can not seect anything except for any text/annotation that has been added in the drawing file.
If I turn on the back clip volume, then I can select elements in this, but still not elements in the forward or cut plane.
