Clash Suppression of AECOsim objects
I am trying to write a Suppression Rule.  I need the rule to suppress the clashes between two different types of Catalog Types AND two different Catalog Instances.
So...
I just can't say "Don't Clash Beams and Wall Leafs" (Catalog Type versus Catalog Type)
I need to say "Don't Clash Beam | Steel Beam versus Wall | <insert Wall Type Here>)  which is Catalog Instance versus Catalog Instance.  Also, all Catalog Types of each type go on the same Level per standards, so I can't change the level of the assigned part.
My closes rule is the first rule that is a regular expression of an element in a file with a logical name...but that doesn't seem to be working....
What I really want is to clash Part versus Part like I used to in Enterprise Navigator
IF (Class("TriForma_Group) and (Part == "name of one part"))
AND
 (Class("TriForma_Group) and (Part == "name of another part"))
THEN $SUPRESS = TRUE
but I can't seem to get the right rule.
Any thoughts?
