Place Wall and Build Wall Assembly Fatal Error
ABD 08.11.09.593
We have been experiencing ongoing issues with the above tools.
Initially everything works as intended after install, however after some time we experience an exception error on all files when initating either of the two tools with the following message dialog:
ListBox StringLists must have at least one infoField; see item of type 'ListBox', id=341003 from "TFWALL"
Has anyone else encountered this?
It would seem that it occurs only when the system is accessing the company datasets located on our central server.
If we choose to 'ignore' the problem on the exception error dialog box the tool then initiates.
I have tried deleting the 'wallszs.rsc' in the dataset 'data' folder to no avail.
Any advice would be most welcome as it is really impacting production.
