What is going on when MicroStation Visibility Calculator runs?
I have a file with no elements and one ref with some geometry (actually a dwg of 25 MB).
I create a BV and place it as separate Model in the same file.
I open ABDss4 and the file with default Model, the 3d. Takes some 30 seconds.
I then use Models dialog to open a Model with a plan BV.
I takes about 9 seconds and I get all geometry displayed on screen.
BUT  I can't do anything for more than 20 seconds more!?
First Mesage Center says - Processing MicroStation Visibility Calculator
Then
MicroStation Visibility Calculator took longer than expected! (23.5 seconds)
and I can start working.
What is going on and why can't I start working after the 9 seconds when I see all geometry?
Parents Reply Children
