Hi, we use Bentley Architecture 08.11.07.87 on our projects and found the following problem.
When we open the Floor Manager (Floor_Master.dgn) we are able to create new buildings and floors, but when we open any dgn file, and open the floor selector, no buildings or floors are listed...going back to the floor manager, they disappeared a well!
I made sure the variable BB_FLOORMASTER_DGN is pointing to the correct file (Floor_Master.dgn), also used Save Settings.
Any idea why they are not saved??
TIA
Do you have read/write priviledges for the Floor_Master.dgn?
-Travis
Thanks for the reply...I am the Administrator with full access.
Any other ideas?
Tx
After adding floors by directly opening the DGNlib, have you reopened the file a second time to be sure they're still there?
Not sure what you mean when you say "Adding floors by directly opening the DGNlib", I want to add floors in the Floor Manager...
Also, would using the floor manager be a suitable option for large projects? Using references must be the better option, what would Bentley suggest?
Sorry, my fault...
If you open the BB_Floormaster.dgnlib directly, are the floors you created displayed? You should be able to see them using either the Floor Manager option in the Building Designer pulldown menu or the Item Browser (File pulldown menu).
